Need info on Pro Foreman shipping weight and number of packages (solved)
Hi all ,
I’m new to this forum and am real keen to purchase a Pro Foreman .
My problem is I live in the middle of nowhere in Florida and need a service for final delivery to my home .
I have reached out to Onefinity via a couple emails and then via landline yesterday and spoke with someone who said I should email the info address. I mentioned I had already emailed a couple times without an answer . They found the email and said they would reply , but still nothing .
Perhaps someone in the community can help with a few questions I have .
What is the total shipping weight and number of packages of the Pro Foreman ?
Why do I not see to many Dewalt DW routers or one of the other brands featured with onefinity machines ?
What is the possibility of mounting the machine at 30 degrees off horizontal ,Y axis left to right ? In this attitude I can easily load sheet stock from a feed in table against a fence for repeatability and easy removal.
I would appreciate any info you guys have to offer
Troy
Info only saw one email and responded this morning:
Hi Troy,
It was nice speaking to you yesterday.
The Pro Foreman ships out in 4-5 boxes (normally 4 but could be 5 if you included the stiffy option https://www.onefinitycnc.com/product-page/x-50-stiffy-journeyman ) Weight without the stiffy - 195 lb Box Dimensions - 3 boxes @ 68" x 14" x 11" and 1 box @ 18" x 9" x 8"
Weight with Stiffy - 225 lbs Box Dimensions - 3 boxes @ 68" x 14" x 11", 1 box @ 66" x 10" x 9", and 1 box @ 18" x 9" x 8"
You are able to use other routers than the Makita one. However, Dewalt does have a 68 mm diameter as the Makita has 65 mm diameter.
If there is anything else we can assist with, please let us know.
Thank you
Best Regards,
Onefinity Team
@MyersWoodshop sells a 80mm to 68mm (dewalt) adapter shim on his esty for the onefinity here:
Thank you :pray:t3: for rapid response. I have passed on the info to the transport company and await a reply .
I have another question if I may .
What is the lead time from order and payment to delivery in Miami Florida for the Pro Foreman ? I will be traveling a bit in the next couple months and don’t want to be away when the shipment arrives
Lead times here, as always: https://www.onefinitycnc.com/order-info
Hey Troy,
Onefinity offers milling motor mounts with 65 am 80 mm. The Dewalt DWP611 hand trim router has 68 mm so does not fit.
The hand trim routers Makita RT0702C, or better, since with real ER collet (far superior to Makita collet), the Carbide ER-11 Compact Router - Carbide 3D or the MakerMade CNC Router with ER-11 collet, have 65 mm diameter. See here for details. 80 mm is for 80 mm cylindrical spindle like Mechatron HFS-8022 (liquid-cooled) or HFSAC-8022 (air-cooled)
Welcome to the forum!
Thank you for the info :pray:t3:. Only problem is my power is 110 v 60 hz so non of the European options help me :disappointed_relieved: . I am leaning towards a water cooled spindle more than a router for a whole bunch of reasons . Was just wondering why the Makita seemed so popular.
Hey Troy,
there is a version of Makita hand trim router for girly power called Makita RT0701C (it even has imperial collets sizes), and the Carbide ER-11 Compact Router - Carbide 3D, and the MakerMade CNC Router with ER-11 collet are available for 110 V too.
By the way, 230 V is not the “European” option, but the whole world option (except North and Latin America).
Regarding spindles, …
  • List item
You’re forgetting Japan ,108 v Brasil has 115v and 230v 60 hz , parts of Argentina as well . In fact most of South America is 220 or 230 v .The US does have 220 v 60 hz as well as 208 v 60 hz , 360 v 60 hz and 480 v 60 hz . I’m sure you’re just taking a dig at girly power :rofl:, but no matter , it still gets the job done
Hey Ron,
Okay, you are right:
So now I write:
“By the way, 230 V is not the “European” option, but the whole world option (except North and the middle part of Latin America and Japan.”
– Source: SomnusDe, Public domain, via Wikimedia Commons
Image: Mains electricity by country
I don’t see the point of mentioning this because I refered to the usual electricity in domestic areas, which is split-phase electricity in the U.S. which provides 120 V and 240 V (the latter for heaters, ovens, air conditioners, table saws, router tables, dust collection systems, and also CNC spindles.) etc., and I did not refer to three-phase electricity as found in industrial and commercial areas. The map does not intend to show such.
For exact details on both single-phase domestic and three-phase electricity, and also on the plugs used, see this list of voltage, frequencies and plugs for every country. E.g. in Europe we have three-phase electricity everywhere as domestic electricity, which provides 230 V between one hot and neutral, and 400 V between each of the three phases.
I just wanted to point on the fact that the 200-240 V class is no “European” option, but the most wide spread voltage in the world. And that the 100-127 V class is unknown outside of North America and the center part of Latin America, and Japan.
Ummm…so nearly half the earth? :wink::face_savoring_food:
Western hemisphere shaming going on here eh? :joy:
