With respect to support. I understand that you do not support VFDs but the onefinity software supports modbus communications, has preconfigured and custom options along with supporting PWM comms for use with lasers. When modbus comms work in one version then not in a another it is, in my opinion, a support issue. It would be a poor showing if 1F could not support modbus.
Okay so. I was trying to get video of loading a file that wouldn’t generate the 3d view. But instead I got a video of the firmware NOT going to the loaded file… here’s the video
Go to firmware home screen and navigate to general section
Select Upgrade via file option
Select the tar.bz2 file from USB drive
It will update the firmware with latest patch.
Select the G-Code which you want to run
Again, navigate to General tab (Under admin section)
Click on View report
It will open in separate tab – kindly save the log into USB drive
Continue your process of cutting the wood Or Job
If you see the issue/Error. Kindly go back to the tab and refresh and save the logs
Note : Issue might not happen at the first time, incase it happened after 1st time kindly repeat the steps from 7 to 12. Kindly share the logs to Developer@onefinitycnc.com for us to investigate the issue. Much appreciated your support here.
There is no difference in this patch (i.e., version and UI everything is same), we have added additional logs to it. Now you can test and replicate the scenario and collect the logs as we suggested, so that we will look into the logs and understand the issue more clearly.
HI, Forgive me if this has been raised and solved else where, but I’ve noticed since upgrading my firmware to 1.2.1 I now have to erase all the files before I can load another by wifi, if I don’t it just leaves the existing active file.
Hi,
Is there a bug list for 1.1.1?
With that we can decide if we want to stay on it and wait for 2.0 vs. 1.2.
When is the release of 2.0 planned?
You need to sell on your site a drive for the sd card reader since it now a requirement to need.
I have the same issue but it also happens when using a USB stick. The only way I have found to clear the file is to reboot the controller. If I just delete the file from the controller I can’t do anything because I get “Over” and/or “Under” errors on at least one axis, and the home function does not clear them.
