Has anyone experienced their monitor going blank when they turn the power “off” to the Makita and returns to normal after several seconds? The electrical cord to Makita is not close to anything else because it is mounted with vacuum hose. My electrical 4 plug outlet is several feet away from Controller and Monitor where everything is gang feed. Weird!
Emi goes through the circuits that everything is plugged into: 10.8" Monitor: How to connect it to power and the controller
Power adapter block? I have a Asus 17" monitor with no adapter block. Does Best Buy have them? Adapter block have something to do with harmonics? Thanks for the quick reply!
the controller cannot power the screen. You’re screen MUST be connected to an external power (wall outlet) source for power.
