Spindle cable management
I have got everything up and running on the install of the elite foreman. Wondering what people have found that works for managing the spindle cable?
I ran mine in the drag chain. No problems.
Hey woodskills,
If you find drag chains too complicated, there are also simpler solutions like this one.
See also
So did I…worked great.
If you run it through the drag chain did you have to take connector off to go through the end part of the drag change? All the links in the drain chain you can open but not the ends.
Thanks all. It first looked like the drag chain ends were sonic welded. Wrong. Using a screwdriver you can pry it apart. Once I saw that, ran the spindle cable through drag chain. It works great.
