Ensure that your breakout board is fully tighten (use the hand screw to fix it). Mine did not connect when I first plug it to test. It took me few time to get it work.
Then compare your PD settings using this:
note: you can skip section ‘Configuration to trigger SSR’.
[link] (Information to build you own Onefinity Companion Control Box - #21 by blaghislain)
