Weird bahavior between controller and 110 volt 2,2 kw Huanyang Spindle
Hey MstrODstr,
besides a faulty VFD, it could be an EMI issue. This is supported by the fact that when the spindle is off, the Modbus communication goes. The spindle and the VFD are a both a heavy source of EMI, it is important that all cables are shielded and their shielded ends are terminated correctly.
Does your X carriage go to the home position at the end of the program, i.e. does it approach the CNC Controller or the VFD? Could you check if the issue appears when the spindle approaches them, and disappears when the spindle is in the right rear corner (assuming that CNC Controller and VFD are on the front left of the machine)? If so,
on all cables, best at both ends.
Do you also have the monitor intermittent issue?
