Z Slider mount hitting on Y axis when homing
Good Afternoon everyone!
I have the Journeyman and every time I home it when it goes all the way to the left to home the X axis the z slider pushes against the Y axis. Is this normal? The machine shudders a little upon impact but then it just completes the homing like I assume it should. I just want to make sure there isn’t something installed incorrectly, and that I’m not causing any damage doing this.
TIA for any advice.
  • A-A-Ron
This is normal and by design. Stuttering is normal and part of the stall homing.
I had this issue check here Proper Motor Settings for x-50 rails (Woodworker and Journeyman), with 1616 ball screw configuration
I can’t find the post but some on the forum printed a spacer so the mount bumped that rather than the z bracket (fears it might be knocking out if tram)
Good morning Andy,
I have it bookmarked, here it is:
Also Stops for Homing
I got it all figured out, Thank you all so much for the great information!
