My monitor is now intermittent. It is turning the screen on and off. It is not losing power or connection. I have checked connections but just cannot stop the problem. This is a new issue.
Any ideas or suggestions
I have the same issue. emailed tech support and they said to make sure you turn monitor on first and not have spindle or other things plugged in with controller and monitor. I had just changed my spindle cooler to the plug strip with controller and monitor and that may have caused it. It did not do it today to my knowledge. It seemed to do it with intense g-code activity. Another thread said it was overloading the PI cpu and that Onefinity is looking to fix if possible
Thank you for the info. All connections are correct and in place. The power is separate. So I am trying the ferrite rings suggested
If no luck I will consider a different monitor.
What is this thick cord that the monitor mount is right next to? Router cable?
The router sends the dirtiest signal. Being far away from the cable would be ideal
Thank you for all the EMI talk. The ferrite rings fixed my small monitor problem of blinking off and on during a run that I’ve had for the last several months.
BTW, the moon is in the seventh house (or at least it use to be!)
Pony
