Opportunity per region for a side hustle @349iq2345 : “Spindle Installer”. I’m sure many would pay a small sum to offset days of fumbling through VFD settings.
Saying that I think I can download my settings from my VFD as backups. Is this possible with others? We could then share the files plus a few tweaks (but it would be a downer on the side hustle )
Thanks for asking, no I have not. i moved forward with carving so I can get the beast running & cutting. All working great. But, no control from the Controller to VFD. I tried termination, all baud rates, shielded-twisted cable. All VFD profiles in the drop down. Changing address. All equated to hair loss.
Well, either the signal is not leaving the breakout board, or the VFD is not receiving it. This is a pretty easy setup - I doubt by this time that you haven’t gotten it. As a trouble-shooting step, my next try would be a different VFD.
I have a 1.5kw 110v VFD that I’m not using at the moment - if you’ll pay shipping I’ll let you test with it…
Sorry for bumping an old thread, but I spent many hours on exactly this issue and finally managed to find a solution. If anyone is still stuck; the cause of my issues turned out to be two-fold:
I had a good signal on the 485+ pin, none on the 485- pin (checked with oscilloscope).Turns out the DB25 connector had some poor solder joints on the board, I applied some new flux and solder after which the signal was fine. (I think this is why some people are saying you need to screw the connector down tightly… this may push loose pins back against the pcb).
Still had the “timeout” message when trying to connect to the VFD. Changing the baudrate from 9600 to 19200 on both sides (value 2 for F164 on the HY VFD) solved this. I haven’t checked whether the actual operation worked at 9600b/s, maybe it’s just the timeout label that misbehaved at the default baudrate. I can’t explain this behavior at a signal level, lower should be more stable if anything. The Onefinity does seem to inverse the polarity each “ping” message, probably so you can connect the + and - (A and B) the wrong way around and it will still work, but this means half the messages are garbage and will not receive an answer. Maybe that triggers the timeout at the lowest baudrate; just guessing.
I assume you mean the board of the breakout board adapter (not the Onefinity Controller Mainboard).
This is very interesting and precious information for the many that report failures with this. Thank you for reporting this!
I already thought that many of the issues that appear because of the problems that Ghislain reported here would not have appeared if people didn’t use these cheap breakout board adapters but wired a good cable to a branded DB-25 plug directly.
Hey thank you very much for posting on thread I have still struggled with this and have left for dead since I didn’t think there was a solution I’ll give that a try and again report back really do appreciate it have an awesome day
I actually was talking about the main Onefinity (Buildbotics) control PCB, not the breakout board adapter! I should have been more clear on that. Also, I can imagine not everyone wants to try this repair for that reason. After previous experiences I expect zero support or warranty from Onefinity, so I do not mind taking my machine apart and making changes to it.
Note that they don’t buy the mainboard from buildbotics, they make their own. See here vs. here. You can see routing differences, e.g. since they moved away external power connector and wanted the other connectors (touch probe, laser, L1 & L2 etc.) externally on back plate.
Thanks for this helpful thread. I’m getting rs485 timeouts trying to get it setup, and this gave me a lot of things to try. Is there a way to test/debug if the controller db25 output is getting signal without an oscilloscope? Or maybe I’ll need to try connecting the vfd to another controller.
yes, if the controller gets the signal, it ceases to report timeouts. Ensure having the right settings for serial connection.
I would think of hardware failures like bad cable and also what Hans reported above:
Hans made clear that he means the DB-25 on Onefinity Mainboard, so I would check continuity between mainboard pcb points and pin outputs of DB-25 connector with a multimeter (set to ohms). See here for pcb layout & schematic in order to find where pins 13 and 14 reside.
If you have the opportunity, it’s the easy method.
General hint: When attaching ModBus serial line, make sure devices are both grounded and please always ground yourself with a antistatic wristband and avoid the loose cable ends touch the carpet. Wired network connections are ESD
Thanks so much for the help! Fortunately I rechecked all my connections today, found a loose terminal, and it’s working now!
I did learn that if my manual gcode S1000 M3 is below the minimum speed in the controller tool configuration (default 6000) it will fail to work without any error message… S6000 M3 works fine!
just to add for other people looking at this issue, my Huanyang VDF has had the same issue with the timeout. It was the VDF. I have gone through 3 of them while in warranty. I am out of warranty and looking for a better option.
