Journeyman X-50 Drag Chain addition
Good afternoon, All! I am new to the community and have a question for the group. Can someone tell me what sizes and how long of a drag chain I will need for my X-50? For both the “x” & “y” axis? I am trying to outfit my machine before I tear something up!
Russell
Hey Russell,
A full-blown¹ drag chain for the X axis alone, with spindle cable and two coolant hoses has usually to never be less than 50 mm wide. There are some 3D printed parts here and here that give information on the length (but that are clearly not wide enough).
You will find a lot of information here: drag chain
1.)
Full-blown (non-ATC) drag chain width computation:
For the X axis drag chain:
11.8 mm spindle cable + 8 mm Z motor cable + 8 mm coolant hose + 8 mm coolant hose + 4 mm signal cable for Z limit sensor + 2 mm distance between every single cable, ensured by the strain relief 3D printed part = 50 mm
11.8 mm spindle cable + 8 mm Z motor cable + 8 mm coolant hose + 8 mm coolant hose + 4 mm signal cable for Z limit sensor + 4 mm for light at spindle + 2 mm distance between every single cable, ensured by the strain relief 3D printed part = 56 mm
For the Y axis drag chain, add the cable for the X stepper motor and the X limit sensor (= additional 12 mm (8 mm + 4 mm) which would mean 70 rsp. 76 mm.
Note that for spindles with sealing air, spindles with a temperature sensor, and for ATC spindles, for workpiece air, flood or mist coolant, oilers, and a camera, you need even more hoses for the compressed air, workpiece coolant, workpiece cutting fluid, axis oiler lines, and cables (see here for an example).
Morning!
I bought 2 of these 18x50 from Amazon for my X50 and for yours you will need 3 pieces instead of 2 (for the 48" run you will link 2 pieces together.)
I use a shielded cable and 3/8" rubber cooling lines. I also run the laser control in the same chains. I did not use any 3D printed parts but I cut some metal brackets out of aluminum L-bracket material. 3D printed parts might have made it a little better, but it has worked great and for more than a year and looks very clean.
Be blessed!
Bill C.
Thank you!
This is great information, and I appreciate the reply.
Russell
Thank you Bill, this helps a lot!
Russell
