Onefinity Foreman Pro ordered with out the black box
Just pulled the trigger, I have a Masso G3 already so I did not get the black box on this machine. My question is do need new cables to install my controller?
Hey hyspead,
if you bought a Masso G3 directly at the Masso shop, then probably…
The MASSO G3 is a universal CNC controller. It can be set up and wired to fit any CNC machine, as it supports a wide variety of motors. → Masso Documentation is the link on how to achieve that.
Welcome to the forum!
I have the Masso controller limit switch’s and pendant, already brought from a friend, so the bare bone machine dos not come with a power supply?
precisely, the buildbotics-derived Onefinity Controller has its power supply inside the case.
Hello all, the x50 pro is setup masso installed with the masso motors and some great Panasonic pm-l25 limit Switches (get some). The problems im having are my projects and not aligning on the machine correctly, I create a 8" on a 15" squared peace of mdf upload the good after homing the maching and setting the xy on the material with my touch probe, everything is great util i start the process the machine know matter the settings in vetric plunge over half way threw the material and the carves seems to be to big but i cannot tell because i cannot complete a carve, any help is greatly appreciated
you need to set the black box up to your specific machine.
Sorry, im not running the black box, I have x50 pro with the masso controller that i already had new and purchased the masso motors later all of my wiring is custom, im basically troubled with PPR, accelaration and depth of cut,
Everything is up and running, looking fornthe vest options for ATC
