Screen frozen cant click on anything
Hey Bradley,
you posted this on the category “Original/PRO” so you have the buildbotics-derived Onefinity Controller? If so, you should check the touch device which is a USB device inside the monitor, but has a connector and cable of its own. Therefore you need three (3) cables to connect the touch display: The HDMI signal cable, the USB touch cable, and finally the display power cable. Check that all are seated properly and that the USB touch cable is a full USB cable and not just a power USB cable.
See also:
