This is the first build of 2.0 Onefinity Firmware.
This has a major rebuild that is 64 bit which will work with either RPI3 or RPI4.
Known Issues:
1366x768 resolution does not work on RPI4 Only
DO NOT INSTALL THIS FIRMWARE IF YOU DO NOT WANT TO HELP BUG TEST. IT IS NOT READY FOR PRODUCTION. THERE WILL BE BUGS.
New features
Raspberry PI4 is now supported!
Added a new Wifi browser to the Network page
The Settings page now allows the user to rotate the screen when mounting it upside down
The Settings page now allows the user to set the time and timezone
GCode files up to 1GB are now supported, and progress is displayed during upload.
Support for many new types of gamepads (including XBox 360, XBox One, Playstation 4, Playstation 5)
User interface improvements
Rebuilt the user experience for probing to make it clearer, easier to use, and more informative.
The āUnitsā display on the main screen is now āDisplay Unitsā. Changing the setting only affects what you see in the user interface, and does not change the machineās unit setting for movements.
Redesigned the top header, moved IP address and Wifi SSID to Network page
Redesigned the Network page
Many minor user interface improvements and tweaks
Bug fixes
Fixed the long/slow movement bug where the machine would fail long and slow movements.
Fixed the āstick driftā issue with some gamepads
Fixed the āstuck in joggingā bug
The Z-axis is now lifted by 25 mm (up from 3 mm) after a Z-axis probe
Screen resolution is now correct on all supported screens, and behaves correctly if the screen is plugged in after the controller has started.
Older controllers with a ātoggleā style power switch no longer display ākernel panicā at shutdown.
Switched from disk-based swap to zram-based swap, to extend the lifespan of the controller sd-card
Rebuild the time/timezone dialog to work better with the virtual keyboard
The time is now displayed in 12-hour format, rather than 24-hour format
Improved gamepad support to properly recognize more gamepads
Added full support for the Logitech F310 gamepad
Added an item on the Settings page to change the default gamepad type
Added a āRemote Diagnosticsā feature to the Help page, to allow support to gather information when diagnosing customer issues.
The most recently uploaded file is now selected after upload
Fixed a problem with uploaded files that contained āoddā characters
Fixed a bug that could cause the touchscreen interface to āhangā for up to a couple of minutes, after an estop
Brought back the ādisable safety promptsā option for probing, with a warning about āliving dangerouslyā
The āSaveā button is now enabled immediately when changing anything on the Settings/Motor/IO/Tool pages
If you experience issues or bugs, you must comment on this thread for us to see them. This thread is the ONLY place the developers will look to fix bugs, if you donāt post them here, they will not be fixed. By downloading the link below, you agree to post about bugs on this thread, and only on this thread (and not on the facebook group, the developers will not see it there and any facebook posts related to 2.0 alpha builds will be deleted immediately).
I didnāt get a ton of time to play with the new build but a few things that I did notice that I wanted to point out.
On the initial bootup after it asked me to sign back into Wi-Fi, the next box does not light up. It was confusing on what I needed to do. I saw that ārefresh wifiā but was afraid to hit it in fear of doing something I shouldnāt. I eventually hit the unlit Next button, then hit the blue refresh bottom and it rebooted.
After it rebooted it got stuck on the loading last file popup. I could it said rendering 0% and never moved. I waited 3 min then decided to flip the power switch as everything was frozen. After I let it sit for a min I flipped the power back on and that time the render window popped up and quickly disappeared.
Next step was to clear the settings, I went through all the screens and took pictures of my current settings then hit reset. Everything seemed to reset perfectly. I then rebooted without issue. However after dismissing the ādo you want to home boxā, and clicking through all of the settings pages to make sure they matched the pictures I took (which they did) I hit control, but the flyout handle that allows you to minimize the gray bar disappeared and no matter which screen I scrolled to I was never able to close that side flyout. That grayed out āsaveā did not click or action at all either.
Oh one last thing, on the first screen when it says pick your button. I was also very confused, had I not just watched the how to flash the SD card YouTube video I would have had no idea what to do there. It needs more clarification (maybe a graphic of the front of the controller or something) that lets you know you are selecting what type of power switch your version has.
I will play with it more this weekend when I have more time, but hopefully that is of some help. It does seem to me faster in booting up and the new loading graphic with the green pill bars that flow across is very cool.
Start sequence, configuration motor settings all work as normal.
Issues with āchange time/zoneā does not prompt to save and time on control screen doesnāt match. (Iām not connected online).
Probe xyz and probe z and return to xy origin work well.
Slow response to open a new fileā¦about 10 seconds before it registered on the screen as loading.
Biggest issue is with lag in screen time (see attached video)
Remaining carve time countdown is slow. Pausing the carve, the countdown continues until caught up
At end of carve, the remaining time showed 25 minutes remaining and continued to count down at slower rate than actual time and many function keys were greyed out preventing loading new file, zeroing an axis or return to home.
This weekend I had a lot of OneFinity time, one thing that I noticed (minor issue) was that on the OF monitor it showed the time remaining in an odd way. However the pic taken a second later on the remote IP in view shows the time correctly.
Also interesting that the OF screen shows 24-hr format but my Web view shows 12h format.
Everything else seem to work flawlessly. I was having an issue an issue a few weeks back that when you load a new file (tried various files) they imported into the OF but did not load into the current to work box. So I carved a file that was a drilling file after I had already run it and switched to the v-bit file and the v-bit dove into the drilled holesā¦ not fun. I slammed the estop and just clicked the file in the loaded files dropdown and it cut perfectly.
Yesterday I noticed a new bug in in the 2.0. When I booted up the machine it went to the load file flow and I waited 5 min and the file never got off 0%. It never asked me to Home, which I found odd as that is always the first step.
The file that I it was trying to load was one that I carved 3x of earlier in the week so it was not a file corruption issue.
Hope it helps, sorry I donāt have more to go on, but the picture I took.
I am probably out of warranty anywayā¦ Original order in the #!4000s
If I crack open this controller, and swap out the piā¦ and I completely nuke thingsā¦ are you going to āhelp me outā with a replacement?
umā¦ ouch. I guess if I nuke it, I will just wait for the upgrade program, order the new one and claim the controller worked fine when I shipped it backā¦
I do appreciate the banter. And for the record, I am not a person that would do that type of thing.
I have a few RPIs laying about. I just downloaded the firmware and will get it swapped (maybe) tonight. I will report back what I see and what features seem to work and which do not.
Do you have a document on how to swap out the rpi?
